Forum >SHT20 Temperature Range
Easy IoT General
userHead Account cancelled 2018-11-28 03:55:25 3219 Views1 Replies
As per information available on https://www.dfrobot.com/wiki/index.php/ ... U:_SEN0227, The temperature range for SKU:SEN0227 package is -40 to 125 degree Celsius. I assume the data is from SHT20 data sheet. Have you tested the SEN0227 packaging in -40 to 125 degree celsius range?
I am planning to test the sensor with existing packaging in real environment, where temperature may change within -40 to 125 degrees. I am concerned whether the sensor's waterproof packaging will last for this range. May you provide me some certificate with test-results for the above mentioned range?
Regards,
Prashant Sangal
2018-12-20 18:53:09 The temperature range is got from the datasheet, we did not test it in real environment before. userHeadPic robert.chen
