DFRobot Fritzing Library
userHead Hector 2012-04-24 01:09:52 32202 Views20 Replies
Hey all,
We have released our Fritzing library! Please take a look.
2013-06-17 20:40:03 what I did on latest version of fritzing was to drag the fritzing library directly into the window, and it worked for me. but not if I try to open it from the menus manually. userHeadPic Jose
2013-06-15 05:43:40 I can not get this to work. Fritzing wont add anything when I import the file userHeadPic The Crusher
2013-01-18 07:12:44 X board V2 has some troubles, some connectors are unselectables in PCB view,  MOSI - MISO - SCK and RESET are missing. It's too bad. userHeadPic essilight
2012-12-31 13:40:55 Hi there hector,
I just downloaded the fritzing-library and imported it to fritzing. But unfortunately there is no I2C/TWI LCD2004 Module included. Where can I get this or could you please implement this part in the library?
Thanks so far....
Greetings,
stetsc
userHeadPic stetsc
Thanks so far....
Greetings,
stetsc
userHeadPic stetsc
2012-05-07 18:42:24 Hey,
I'm glad we could help XD Please give us some feedback about our fritzing library.
userHeadPic Hector
userHeadPic Hector
2012-05-07 11:40:30 Thanks a lot you guys, this is why I love Open Source! userHeadPic Firemann00b
2012-05-04 21:27:17 Hi,
We have added the motor shield to the library as a stand alone file. Please download it from the git
https://github.com/DFRobot/Fritzing-library
There is a minor problem, we could not get the D0 pin to behave with out it causing other problems. So it has been omitted
userHeadPic Hector
userHeadPic Hector
2012-05-01 16:40:08 sure. will release them within two days. userHeadPic R2D2C3PO
2012-05-01 11:06:31 The motor shield 2A is missing in this library :( Could someone add it please? I've got a school project and I have to hand in a CAD drawing in a couple of weeks. userHeadPic Firemann00b
2012-04-24 01:09:52 Hey all,
userHeadPic Hector
