Forum >Pirate-4WD Mobile Platform- 4 motor-control
I would want to know if it is possible to control 4 motors independently using Romeo All-In-One controller. Now I am using M1 and M2 to control the 4 motors, but I have to connect two motors in each motor-module. Is any way to be able to control the 4 motors independently?
Thank you
Thank you
2015-02-26 02:30:08 hi,
if your motor use 5V and <200mA, you could use the other empty digital pwm pins.
Leff
