Forum >Connecting to a Bluno using CoreBluetooth ...connects then disconnects
userHead ipatch 2014-01-31 13:29:15 2674 Views0 Replies
Hello, I currently have the Bluno v1.6 and I am trying to connect to the device via BLE using CoreBluetooth provided by Apple. My app attemps to connect to the device for a second or two then disconnects. I am not sure why the device is doing this but the Bluno has no problem connecting to the app LightBlue, and staying connected.
My code is as follows,
ViewControllerDev2.m
- (void)viewDidLoad {
_centralManager = [[CBCentralManager alloc] initWithDelegate:self queue:nil options:nil]; // options:nil is an iOS 7 feature
// this method is called when creating a CBCentralManager, and is required!
// this method ensures that BLE is supported and available to use on the central device.
// the protocol allows the delegate to monitor the discovery, connectivity, and retrieval of peripheral devices.
- (void)centralManagerDidUpdateState:(CBCentralManager *)central
// You should test all scenarios
if (central.state != CBCentralManagerStatePoweredOn) {
return;
if (central.state == CBCentralManagerStatePoweredOn) {
// Scan for devices
[_centralManager scanForPeripheralsWithServices:@[[CBUUID UUIDWithString:BLUNO_TRANSFER_SERVICE_UUID]] options:@{ CBCentralManagerScanOptionAllowDuplicatesKey : @YES }];
NSLog(@"Scanning started");
// this method is called after the central manager discovers a peripheral.
// "Any peripheral that is discovered is returned as a CBPeripheral object"
- (void)centralManager:(CBCentralManager *)central didDiscoverPeripheral:(CBPeripheral *)peripheral advertisementData:(NSDictionary *)advertisementData RSSI:(NSNumber *)RSSI {
NSLog(@"Discovered %@ at %@", peripheral.name, RSSI);
if (_discoveredPeripheral != peripheral) {
// Save a local copy of the peripheral, so CoreBluetooth doesn't get rid of it
_discoveredPeripheral = peripheral;
// And connect
NSLog(@"Connecting to peripheral %@", peripheral);
[_centralManager connectPeripheral:peripheral options:nil];
// then stop scanning for peripherals
[_centralManager stopScan];
NSLog(@"Scanning stopped");
// if the connection request is successful, the central manager calls the following method of its delegate object.
- (void)centralManager:(CBCentralManager *)central didConnectPeripheral:(CBPeripheral *)peripheral {
NSLog(@"Peripheral Connected");
peripheral.delegate = self;
[_data setLength:0];
// discover the services offered by the peripheral
[peripheral discoverServices:@[[CBUUID UUIDWithString:BLUNO_TRANSFER_SERVICE_UUID]]];
// this method is called once a service of a peripheral is discovered.
- (void)peripheral:(CBPeripheral *)peripheral didDiscoverServices:(NSError *)error {
if (error) {
[self cleanup];
return;
for (CBService *service in peripheral.services) {
[peripheral discoverCharacteristics:@[[CBUUID UUIDWithString:BLUNO_TRANSFER_CHARACTERISTIC_UUID]] forService:service];
// Discover other characteristics
