Forum >Bluno external input voltage
userHead djh_83 2015-03-27 13:49:32 2278 Views2 Replies
I have a Bluno connected to a 12volt battery, will also be installing a solar panel to keep the battery charged, the specs on solar panel suggest that the charging voltage can go as high as 20.8 volts. Is that outside of the external input range for the Bluno? Bluno mega specs the range at 6 to 20v. No such spec on the Bluno page though
2015-04-01 05:44:10 Thanks, ill be implementing a solar charge controller to avoid the charge going over 12 volts userHeadPic djh_83
2015-03-31 01:11:04 Hello,
Actually, the power chip could stand 23V power supply. And 20V is just the safe value.
When the power voltage is higher than 12, the chip will be hot. So it is better to make a separated battery charging.
userHeadPic Grey.CC
