Forum >DFPlayer - how to pause after each song
Is there a simple solution how to do it without external MCU ? Just on switches and appropriate wiring.
Player must pause after each song and wait for the trigger.
I must play play list in loop.
I've looked into the datasheet but I don't get it.
2015-08-08 02:55:41 Hi,
Too bad. For my application this is essential.
One more question.
Is there a possibility that dfPalyer will remember last played song after power off?
What I want is to after power on DFPlayer start song in the remembered location.
Is it possible without MCU?
projekty
One more question.
One more question.
projekty
One more question.
2015-05-13 21:17:27 What about the current consumption?
Can it be lower?
Actual measured consumption is around 15mA. But I need to set approx 5mA.
projekty
Can it be lower?
Can it be lower?
projekty
Can it be lower?
2015-05-08 02:37:46 Hi,
Thanks for a TIP... but:
This is very budget project, I do not use any MCU - only passive components.
So no serial communication.
projekty
2015-05-07 22:20:03 Hi,
DFPlayer tested.
It defaulty stops after each song and wait for a NEXT or PREV switch to be short.
But here is another issue. After power on it sets a default volume on highest level.
How to make this default level somewhere in the middle?
More. Is the 20mA standby current a minimum value?
Is there something like sleep mode that consumes less?
How to set it while not playing using BUSY pin?
Normally I will disconnect module form power but this causes DFPlayer to start play from beginning after power on.
I need to play in cycle all of the time.
projekty
DFPlayer tested.
DFPlayer tested.
projekty
DFPlayer tested.
2015-04-28 05:00:51 Well,
Is it means that if this AD KEY will be shorted for all time the player will play all songs in loop?
I want to avoid adding MCU. This circuit must be as simple as could be.
projekty
2015-04-24 02:23:37 Hi,
i am not familiar with this module, but i checked the
https://www.dfrobot.com/wiki/index.php?title=DFPlayer_Mini_SKU:DFR0299#Connection_Diagram%20wiki%20page
1 AD Key
there is a key called "loop",is it what you want?
2 by the way, with MCU, you could check the player state,whether playing or not, so you could control the player by Serial mode.
Leff
1 AD Key
2015-04-21 22:35:13 Hi,
projekty
