Forum >EAGLE Schematics
EAGLE Schematics
userHead northernalex 2015-05-29 07:04:02 7213 Views7 Replies
Dear All,
I'm trying to put together a circuitboard in Eagle and I want to glue a DFROBOT Beetle onto it to use as a microcontroller which will drive LEDs if certain input conditions are met. Does anyone have an Eagle library for this Beetle so that I can use it as a component in the schematic and also put it onto the circuit board so when I get the board made I can solder connections from the board to the inputs/outputs of the Beetle?
Kind Regards
Alex
2018-10-13 23:50:11 Hi Alex,
Did you manage to find the eagle files for it? I am also looking for them so it would really help me.
Thank you
userHeadPic epesteban96
2018-10-13 23:48:50 Hi Alex,
Thank you
2015-06-17 22:43:09 well, we have put all the documents of each product on the web, at the product page. :roll: But I donnot have that project file. userHeadPic Leff
2015-06-09 04:49:57 Basically I would like this as a CAD drawing
https://www.dfrobot.com/wiki/index.php?t ... e_face.png
Or in the format that I can load directly into the CAM editor of EAGLE
Any ideas?
Alex
userHeadPic northernalex
2015-06-09 04:35:31 Thanks guys, Basically I'm using various sensors that when they are both logic high will output logic high on an output pin that will result in LEDs turning on. Should be simple but I have a circuit board already in eagle that I will glue the BEETLE to, then solder wires from the board onto the BEETLE. I was just wondering if there was a component file for the BEETLE already that has the pad locations etc so that I know where to put the pads to solder the wires to. Looks like this doesn't exit. Will look into programming it myself (unless I can get a gerber file to be converted back into eagle circuit board format).
Cheers all
Alex
2015-06-09 00:30:08
northernalex wrote:Dear All,
Kind Regards
Alex
Hi, Alex,
Do you mean creative Gerber files by Eagle before making circuit board?
if yes, you may have a look at this following link, which show details on how to generate Gerber files from Eagle,
http://pcbprototype5.blogspot.com/2015/ ... -file.html
http://pcbprototype5.blogspot.com/2015/ ... ayout.html
Hope this would be useful for you.
Eosintic
userHeadPic eosintickleear
2015-05-30 01:35:37 Hi ALex,
https://github.com/adafruit/Adafruit-Eagle-Library Is this what you need?
I don't understand your project, do you have a drawing or photo abput your cool idea? ;)
userHeadPic Leff
