Forum >Can I send SMS while GPS/GPRS is on?
userHead wahmalik85 2014-02-19 00:29:24 5153 Views5 Replies
Hi all,
I try to send SMS after reading GPS info and then send the information to server through GPRS,
But when I send the SMS i get
+CMS ERROR: 302
which mean the operation not allowed.
I work based on this code:
https://github.com/DFRobot/GPS-GPRS-GSM ... RS_GPS.ino
any suggestions?
many thanks.
2014-02-25 22:22:56 [quote="Jose"]
let me know if you can keep the GPS while GPRS or SMS is enable without cold resetting.
I'll give it a go in my side.
[/quote]
Yes, I get the GPS coordinates and send them to SMS and GPRS without resetting between GPS and GSM.
^_^
best regards.
userHeadPic wahmalik85
2014-02-25 20:50:32 Great!
I was attempting to get GPS phone calls and GPRS and did not check out that part.
I'm guessing the SMS is working by now in your sketch!
as for the buffer, nice found! not easy to track.
Thanks for sharing!
Cheers^^
userHeadPic Jose
2014-02-25 03:09:00 Hi,
I found 2 problems I faced.
1- I missed to type double quote (") before phone number and after.
what I did is:
Code: Select all
Serial.println("777xxxxxx");
the right is:
Code: Select all
Serial.println("\"777xxxxxx\"");
2- the buffer size of serial was to small (64), so I can not send more than 64 character to the Module, so the AT command considered not complete.
the result would be like:
Code: Select all
+CMS ERROR: 302
2014-02-19 21:13:17 Here is the code:
Code: Select all
#include <Arduino.h>
#include <Wire.h>
char aux_str[30];
char aux;
char latitude[15];
char longitude[15];
char inChar;
int index;
char inData[200];
char par1 [20];
char par2 [20];
char par3 [20];
char par4 [20];
char par5 [20];
char par6 [20];
int loop_no = 0;
/****************************************************************SMS********************/
char phone_no[20];
char inSMS[200];
boolean msgFound = false;
  //Init the driver pins for GSM function
    pinMode(3,OUTPUT);
    pinMode(4,OUTPUT);
    pinMode(5,OUTPUT);
  //Output GSM Timing
    digitalWrite(5,HIGH);
    delay(1500);
    digitalWrite(5,LOW);
    // Use these commands instead of the hardware switch 'UART select' in order to enable each mode
    // If you want to use both GMS and GPS. enable the required one in your code and disable the other one for each access.
    digitalWrite(3,LOW);//enable GSM TX?RX
    digitalWrite(4,HIGH);//disable GPS TX?RX
    delay(2000);
    Serial.begin(9600);
    delay(5000);//call ready
    delay(5000);
    delay(5000);
    start_GSM();
    delay(5000);
    start_GPS();
    delay(500);
  read_GPS();
  delay(2000);
  /****************************************************************SMS*******************/
  SendReadSMSComm();
  if(msgFound)
      //Serial.println("message will be send");
      sendSMS();
      delay(1000);
      DeleteAllMSGs();
  if(loop_no > 0 )
    send_GPRS();
  }else{
    loop_no ++;
  delay(15000);
  msgFound = false;
void SendReadSMSComm()
    Serial.println("AT");
    delay(1000);
    Serial.println("AT+CMGR=1");
    delay(3000);
    readSMS();
    strtok(inSMS, ",");
    strcpy(phone_no,strtok(NULL, ",")); // Gets phone number
    printBuff();
void readSMS()
  index=0;
  while(Serial.available() > 0) // Don't read unless
                                                  // there you know there is data
    if(index < 199) // One less than the size of the array
      inChar = Serial.read(); // Read a character
      inSMS[index] = inChar; // Store it
      index++; // Increment where to write next
      inSMS[index] = '\0'; // Null terminate the string
  if(index > 20)
      msgFound = true;
  }else{
    msgFound = false;
void DeleteAllMSGs()
      delay(1000);
      Serial.println("AT+CMGD=1,4");
      delay(5000);
      printBuff();
void sendSMS()
    delay(1000);
    //Send message
    Serial.println("AT+CMGF=1");
    delay(1000);
    Serial.print("AT+CMGS=");//Change the receiver phone number
    delay(1000);
    Serial.print("lat=");//the message you want to send
    Serial.print(latitude);
    Serial.print(",lon=");
    Serial.print(longitude);
    delay(1000);
    Serial.write(26);
    delay(1000);
    Serial.println();
    printBuff();
void start_GSM(){
    //Configuracion GPRS Claro Argentina
    delay(2000);
    //printBuff();
    Serial.println("AT+CREG?");
    delay(2000);
    //printBuff();
    Serial.println("AT+SAPBR=3,1,\"APN\",\"Fast-Internet\"");
    delay(2000);
    //printBuff();
    Serial.println("AT+SAPBR=3,1,\"USER\",\"net\"");
    delay(2000);
    //printBuff();
    Serial.println("AT+SAPBR=3,1,\"PWD\",\"net\"");
    delay(2000);
    //printBuff();
    Serial.println("AT+SAPBR=3,1,\"Contype\",\"GPRS\"");
    delay(2000);
    //printBuff();
    Serial.println("AT+SAPBR=1,1");
    delay(10000);
    //printBuff();
    Serial.println("AT+HTTPINIT");
    delay(2000);
    //printBuff();
    Serial.println("AT+HTTPPARA=\"CID\",1");
    delay(2000);
    //printBuff();
    clearBuff();
void send_GPRS(){
          Serial.print("AT+HTTPPARA=\"URL\",\"xxxxx.com/gps/geo2_1.php?lat=");
          Serial.print("&lon=");
          Serial.print("&par1=");
          Serial.print(par1);
          Serial.print("&par2=");
          Serial.print(par2);
          Serial.print("&par3=");
          //Serial.print("ok");
          Serial.print(par3);
          Serial.print("&par4=");
          //Serial.print("3555");
          Serial.print(par4);
          Serial.print("&par5=");
          //Serial.print("50251");
          Serial.print(par5);
          Serial.print("&par6=");
          //Serial.print("0.001");
          Serial.print(par6);
          Serial.println("\"");
          delay(2000);
          //waitTillResp();
          Serial.println("AT+HTTPACTION=0"); //now GET action
          delay(2000);
          //waitTillResp();
          clearBuff();
void start_GPS(){
    //Configuracion en Inicializacion GPS
    delay(1000);
    Serial.println("AT+CGPSIPR=9600");// (set the baud rate)
    delay(1000);
    Serial.println("AT+CGPSPWR=1"); // ?turn on GPS power supply?
    delay(1000);
    Serial.println("AT+CGPSRST=1"); //?reset GPS in autonomy mode?
    delay(10000); //delay para esperar señal del GPS
void read_GPS(){
    Serial.println("AT+CGPSINF=0");
    //printBuff();
    read_String();
    strtok(inData, ",");
    strcpy(longitude,strtok(NULL, ",")); // Gets longitude
    strcpy(latitude,strtok(NULL, ",")); // Gets latitude
    strcpy(par1,strtok(NULL, ","));
    strcpy(par2,strtok(NULL, ","));
    strcpy(par3,strtok(NULL, ","));
    strcpy(par4,strtok(NULL, ","));
    strcpy(par5,strtok(NULL, ","));
    strcpy(par6,strtok(NULL, ","));
    convert2Degrees(latitude);
    convert2Degrees(longitude);
void read_String() {
      index=0;
          inData[index] = inChar; // Store it
          inData[index] = '\0'; // Null terminate the string
int8_t convert2Degrees(char* input){
    float deg;
    float minutes;
    boolean neg = false;
    //auxiliar variable
    char aux[10];
    if (input[0] == '-')
        neg = true;
        strcpy(aux, strtok(input+1, "."));
    else
        strcpy(aux, strtok(input, "."));
    // convert string to integer and add it to final float variable
    deg = atof(aux);
    strcpy(aux, strtok(NULL, '\0'));
    minutes=atof(aux);
    minutes/=1000000;
    if (deg < 100)
        minutes += deg;
        deg = 0;
    else
        minutes += int(deg) % 100;
        deg = int(deg) / 100;
    // add minutes to degrees
    deg=deg+minutes/60;
    if (neg == true)
        deg*=-1.0;
    neg = false;
    if( deg < 0 ){
        neg = true;
        deg*=-1;
    float numeroFloat=deg;
    int parteEntera[10];
    int cifra;
    long numero=(long)numeroFloat;
    int size=0;
    while(1){
        size=size+1;
        cifra=numero%10;
        numero=numero/10;
        parteEntera[size-1]=cifra;
        if (numero==0){
            break;
    int indice=0;
    if( neg ){
        indice++;
        input[0]='-';
    for (int i=size-1; i >= 0; i--)
        input[indice]=parteEntera[i]+'0';
        indice++;
    input[indice]='.';
    indice++;
    numeroFloat=(numeroFloat-(int)numeroFloat);
    for (int i=1; i<=6 ; i++)
        numeroFloat=numeroFloat*10;
        cifra= (long)numeroFloat;
        numeroFloat=numeroFloat-cifra;
        input[indice]=char(cifra)+48;
        indice++;
    input[indice]='\0';
void clearBuff(){
  while( Serial.available() > 0)
        Serial.read();    // Clean the input buffer
void printBuff()
    delay(1000);
      Serial.print((char)Serial.read());
    Serial.println("");
    delay(1000);
    clearBuff();
void waitTillResp(){
  int d = 0;
  while(Serial.available() < 1 && d != 10){
    delay(1000);
    d++;
  printBuff();
2014-02-19 00:53:44 I suggest you to check if you still have your services enabled, and try to send a sms manually before testing automatically from Arduino.
Could be that the SMS is not enabled, or the command is malformed.
Best if you send the code / sketch to see where it could be the problem or to try it
userHeadPic Jose
