Forum >My insect bot gose only turn left
The product name is "insect bot Hexa".
The source code was uploaded according to the manual.
Go forward well, but if it meets an obstacle, only turn left.
If an obstacle is in the left, I want it turn right.
How can I modify the source code?
#include <Servo.h>
// creating the servo objects for front, rear and mid servo
Servo frontLeg;
Servo rearLeg;
Servo midLeg;
// setting the servo angle to 90° for startup
byte frontAngle = 90;
byte rearAngle = 90;
byte midAngle = 90;
// setting the delay value
byte delayWalk = 2;
byte delayTurn = 3;
// Analog sensor pins
int distanceSensor = A1;
int lightSensorLeft = A2;
int lightSensorRight = A0;
// Analog sensor reading
int sensorValue = 0;
int leftEye = 0;
int rightEye = 0;
// Values
int sensorValueLeft = 0;
int sensorValueRight = 0;
int left = 0;
int right = 0;
// Change the following value to decrease or increase the sensitivity.
// Bigger value for lower sensitivity and smaller value for highter sensitivity
int lightDifference = 60;
// Decrease the danger value when you want to INCREASE the collision trigger distance.
// Increase the danger value when you want to DECREASE the collision trigger distance
int danger = 450; // Increase this value when you want to DECREASE the collision trigger distance
// Arrays for sensor reading average calculation
int leftReadings[11];
int rightReadings[11];
// Booleans for decision
boolean lightLeft = false;
boolean lightRight = false;
// Setup function
Serial.begin(9600);
// attaching the servos to their pins
frontLeg.attach(9);
rearLeg.attach(10);
midLeg.attach(11);
// move servos to center position -> 90°
frontLeg.write(frontAngle);
rearLeg.write(rearAngle);
midLeg.write(midAngle);
delay(2000);
// Light detection and filtering
void scan()
int i;
// Take 5 readings on each sensor
for (i = 0; i < 11; i = i + 1)
// read the value from the left and right sensor:
sensorValueLeft = analogRead(lightSensorLeft);
sensorValueRight = analogRead(lightSensorRight);
// add sensor readings of both sides to their respective array
leftReadings[i] = sensorValueLeft;
rightReadings[i] = sensorValueRight;
// Sorting the left light sensor values
sort(leftReadings,11);
left = leftReadings[5];
// Sorting the right light sensor values
sort(rightReadings,11);
right = rightReadings[5];
Serial.println(left);
Serial.println(right);
// Sort the array ascending
void sort(int a[], int size)
for(int i=0; i<(size-1); i++)
for(int o=0; o<(size-(i+1)); o++)
if(a[o] > a[o+1])
int t = a[o];
a[o] = a[o+1];
a[o+1] = t;
// Desision depending on the light values
void decision()
scan();
if (left > right)
left = left-right;
if (left > lightDifference)
lightLeft = true;
lightRight = false;
//Serial.print("turn left");
else
lightLeft = true;
lightRight = true;
//Serial.println("go straight1");
else if (left < right)
// subtract left from right value to get a value to work with
right = right-left;
// check if that previous calculated value is greater than 50
if (right > lightDifference) // I will call this "Inside IF 2" in further comments.
lightLeft = false;
lightRight = true;
//Serial.print("turn right");
else
/* Is the calculated value for right lower than 50 then go forward. Why? Is that value lower than 50 then the difference
between the light on the left and right sensor are not that great. In this case it should be save to go forward.
lightLeft = true;
lightRight = true;
//Serial.println("go straight2");
/* That "else" happens when none of the above conditions occur and the left and right sensor shows the same readings.
This condition will probably never occur but we need it anyway.
else
lightLeft = true;
lightRight = true;
//Serial.println("go straight3");
// Walk forward //////////////////////////////////////////////////////////
void forward()
for (midAngle = 70; midAngle < 100; midAngle +=1)
delay(delayWalk);
for (frontAngle = 120; frontAngle > 50; frontAngle -= 1)
rearLeg.write(frontAngle);
delay(delayWalk);
for(midAngle = 100; midAngle > 70; midAngle -=1)
delay(delayWalk);
for(frontAngle = 50; frontAngle < 120; frontAngle += 1)
delay(delayWalk);
// Walk reverse //////////////////////////////////////////////////////////
void reverse()
for(midAngle = 70; midAngle < 100; midAngle +=1)
delay(delayWalk);
delay(delayWalk);
for(midAngle = 100; midAngle > 70; midAngle -=1){
delay(delayWalk);
for(frontAngle = 120; frontAngle > 50; frontAngle -= 1)
delay(delayWalk);
// Left Turn //////////////////////////////////////////////////////////
void leftTurn()
rearLeg.write(90);
for(midAngle = 70; midAngle < 110; midAngle += 1)
delay(delayTurn);
for(frontAngle = 70; frontAngle < 110; frontAngle +=1)
delay(delayTurn);
for (rearAngle = 110; rearAngle > 70; rearAngle -=1){
delay(delayTurn);
for (midAngle = 110; midAngle > 70; midAngle -= 1)
delay(delayTurn);
for (frontAngle = 110; frontAngle > 70; frontAngle -=1)
delay(delayTurn);
for (rearAngle = 70; rearAngle < 110; rearAngle +=1)
delay(delayTurn);
// Right Turn //////////////////////////////////////////////////////////
void rightTurn()
frontLeg.write(90);
for (midAngle = 70; midAngle < 110; midAngle += 1)
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
delay(delayTurn);
for (frontAngle = 70; frontAngle < 110; frontAngle +=1)
delay(delayTurn);
// Stop walking
void stay()
frontLeg.write(90);
midLeg.write(90);
rearLeg.write(90);
scan();
// read the IR distance sensor value
sensorValue = analogRead(distanceSensor);
// Serial.print ("Distance: ");
// Serial.print(sensorValue);
if (sensorValue < danger)
decision();
else
Serial.println("sensorValue > danger");
frontLeg.write(90);
rearLeg.write(90);
midLeg.write(90);
delay(1000);
for (byte x=0; x<5; x+=1)
Serial.println("reverse()");
reverse();
delay(300);
for (byte x=1; x<5; x+=1)
Serial.println("only left");
leftTurn();
delay(300);
decision();
if(lightLeft == true && lightRight == true)
Serial.println("forward()");
forward();
delay(5);
else if (lightLeft == false && lightRight == true)
Serial.println("rightTurn()");
rightTurn();
delay(5);
else if (lightLeft == true && lightRight == false)
Serial.println("leftTurn()");
leftTurn();
delay(5);
else
Serial.println("stay()");
stay();
2015-06-09 02:59:50 Hi,
It seems that there are some offset with light sensor. You will need a zero adjustment.
This are two Analog port which insect are using to read analog light value. You could use the analog simple code to read the light value.
Open the serial monitor,check the value, with the same light, what is their value? Record their value, and make them balance in the code. For example with same light, rightsensor value is higher 12 than leftsensor, then minus 12 on the right side.
Grey.CC
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0); //Right is A0; Left is A2
// print out the value you read:
Serial.println(sensorValue);
delay(100); // delay in between reads for stability
. It should be OK sensorValueRight = analogRead(lightSensorRight)-12;
