Forum >Bluno USB port programming issue
Bluno General Arduino
userHead Grey.CC 2015-06-12 22:33:07 8003 Views7 Replies
There are some points when you fail to upload the Bluno sketch.
1 Check the board selection: Bluno, Bluno nano, Romeo BLE are using ATmega328 microcontroller, so the bootloader is same to Arduino UNO. Bluno Mega1280 = Mega1280 Bluno Mega2560= Mega2560.
2 Disconnect any Serial port device connection. There is only a serial port, so it will be occupied by sketch uploading.
3 Disconnect any wireless connection. Disconnect other bluetooth device connection when you upload the sketch.
4 For Bluno Mega1280, it requires a special driver, plug install the driver first.
Other reasons:
Bluetooth issue: try to upload a new BLE firmware, if you can update the firmware, it means the bluetooth chip is OK.
Bootloader issue: try to upload a new bootloader for ATmega328.
If you find other reason, please supply.
2015-07-01 01:30:32 Oh, cool~
and what might be the reason you guess?
piakster wrote:Hi the problem is solved. I tried multiple times and finally it worked. BLE firmware updated successfully and sketches are uploaded fine.Thanks.
userHeadPic Leff
2015-06-25 23:35:30 Hi the problem is solved. I tried multiple times and finally it worked. BLE firmware updated successfully and sketches are uploaded fine.Thanks. userHeadPic piakster
2015-06-25 20:54:16 Hi Leff,
I get Device malfunction warning. The board is not recognized as a USB drive.
Kelvin
2015-06-25 19:35:07 How about try the step one if the firmware version is 1.6 or below? is that possible?
piakster wrote:Hi Leff,
I am using Win 7.
I tried again and again always getting Time out warning. My board is recognized as Arduino Uno at COM8.
kelvin
userHeadPic Leff
2015-06-25 00:57:05 Hi Leff,
I am using Win 7.
kelvin
2015-06-25 00:44:43 Hi Kelvin,
Have you noticed the computer system requirment. The operation is different if you use win8/7 etc. what's your pc ?
And have you tried to burn firmware again?
piakster wrote:Hi all,
I am having problem with Bluno Nano.
I have been doing some work with Bluno Nano and it was working fine until last Thursday. I could not find the right port on Arduino environment. I followed some instruction to upload new BLE firmware by running the Bluno Downloader. I press and hold the boot button when I connect to USB. I get the LED flashing alternately only once in a while. After choosing the right FW and press Upload, I get Time out warning.
Please advice on how to move on.
Kelvin
userHeadPic Leff
2015-06-24 23:20:25 Hi all,
Kelvin
