Forum >Bluno Nano - BLE send integer
Easy IoT General
userHead kubik 2015-06-17 08:11:07 4591 Views3 Replies
Hi!
I need to sent from arduino (Bluno Nano) couple of INT in less then 1 second.
Can I do it by beacon method (like advertising)?
The other solution is to set name of BLE device to my value. Could you give me advice how to do it?
I try to do it by AT commands but It works very slow. I need to set delay 2000 between commands.
2015-06-23 23:48:30
kubik wrote:I didn't solve this problem. I try with other devices
So you are going to give up the ibeacon idea?
userHeadPic Leff
2015-06-20 04:54:41 I didn't solve this problem. I try with other devices userHeadPic kubik
2015-06-19 20:20:50 I am doing BLE based- tracking project. I also want to use ibeacon method. How is it going about your project. I am not familiar with ibeacon, obscure.
kubik wrote:Hi!
userHeadPic Leff
