Forum >Romeo BLE: Loses Connection
Bluno General Arduino
userHead phil 2015-08-11 20:36:37 4097 Views5 Replies
I have 3 Romeo BLE boards and am having trouble with one of them.
It keeps disconnecting from the goBLE app and I need to re-pair every a few seconds.
when it is connected it seems to work fine.
I am powering 4 motors and using 4xAA batteries.
Any idea why one board would have issues? I have tried multiple iPhones.
Thanks.
Phil
2015-08-31 18:58:52
phil wrote:I updated the firmware and it still loses connection. Not as often but still at least every 30 seconds
May I know more details about your situation about the connection broken?
And sorry I forget to say, when your phone is locked/ the screen is turned off or exit from the APP, then it would run as background app so that will lost connection. This would be fixed in the next version. Is this what you met with?
userHeadPic Leff
2015-08-30 12:55:27 I updated the firmware and it still loses connection. Not as often but still at least every 30 seconds userHeadPic phil
2015-08-12 18:50:40 :)
Update firmware, all could be found on the wiki.
userHeadPic Leff
2015-08-12 11:33:34 Original question:
how can I update the firmware of the Romeo ble?
Hi Phil,
Very sorry that I cliked wrong at the "Edit" instead of "Reply"(Admin ).
Leff
userHeadPic phil
2015-08-12 01:38:55 As long as your phone can be connected with the BLE, then it cannot be the phone problem.
May I confirm again that if there was only one of them having the issue?
If it is, you could try to update its firmware to the latest version.
phil wrote:I have 3 Romeo BLE boards and am having trouble with one of them.
Thanks.
Phil
userHeadPic Leff
