Forum >Minimum gaps and track widths
PCB ServicesGeneral
userHead Oliver Mark 2015-08-25 02:59:17 12781 Views8 Replies
Can anyone tell me for 1mm FR4 what the minimum permissible track width is and also the minimum gap between two tracks? I am using AWR design environment to design a PCB and would prefer to get this information before I start.
Assume a small sized PCB that has a burn boundary track
2020-07-08 14:49:19 The minimum permissible track width :10 mil userHeadPic anonymous
2015-10-16 02:12:27
eWeeeb wrote:hi id say minimum of 25 mil.
yeah, that's much more safe to avoid data interfere. But we usually take lesser.
userHeadPic Leff
2015-10-16 00:37:53 hi id say minimum of 25 mil. userHeadPic eWeeeb
2015-08-28 19:14:00 haha,
but 0.2mm is also ok, it's not that strict.
userHeadPic Leff
2015-08-27 02:36:59 Cheers.
It's not like I'm trying to land a probe on Mars or anything but I'd rather not make that mistake. I have a student here with a pcb design that calls for a 0.20 mm gap I guess he'll have to do some more work on it.
Thanks again
userHeadPic Oliver Mark
2015-08-27 01:55:37 well, I also don't know the unit quite for sure, but I check in dictionary and got this:
mil: a unit of linear measurement equivalent to 0.0254 mm (one thousandth of an inch), often used in measuring the diameter of wires.
so that's _ a mil one thousandth of an inch
Oliver Mark wrote:Hi
Please excuse my ignorance but what is :10 mils? is a mil one thousandth of an inch or millimeter?
Mark
userHeadPic Leff
2015-08-26 06:53:46 Hi
Mark
2015-08-25 22:05:34 Hi Oliver,
This is what we used if we design a pcb.
the minimum gap between two tracks:12-15 mil ( 10mil is also acceptable)
Hope this could help you!
userHeadPic Leff
