Forum >Edison X-Board dimensions
Do you have the exact dimensions for the X-Board (DFR0338), and the position of the mounting holes. We have some boards on the way, and need to get a case ready.
Regards,
Gavin.
Regards,
Gavin.
2015-09-29 20:17:27 Hello Gavin,
Welcome!
Sorry we only have that dimension which you could see in the specification: Size: 70x55x15mm .
The holes' diameter is 3mm, but the distance from the hole to the edge of the board is vary from different boards. So I could could offer a not very accurate dimension for you!
What other demensions do you need?
Leff
Welcome!
