Forum >Re: Noob Help - Bluetooth DAQ Project using the Bluno Beetle
Bluno General Arduino
userHead jdelcamp0 2018-12-27 06:47:26 6401 Views2 Replies
Two things: The dongle appears in the port list as an arduino uno. So the one you are seeing is the dongle.
Also to upload you need to set the baud to 115200. Make sure you also set the baud rate in both the sketch and com window to match.
2020-01-15 22:53:33 Hello
I am just getting started with Bluno Beetle and am so lost. I have a project working with Arduino Uno and want to migrate to Bluno Beetle. I have followed some of the tutorial I found online but I keep running into glitches,
Any good starting points?
userHeadPic mybloodpumpsdiesesl
