Forum >Bluno AT+ Mode
Bluno AT+ Mode
I was able to get into AT mode but after playing with sketches, I am no longer able to use it.
I have the Bluno 1280 and 2560 and both are having the same problem.
I have now uploaded the "Bluno Demo" Sketch like in the Wiki.
I then go to the "serial monitor"
I verified that the first line has "No Editing" and the second box if "9600"
I then type "+++"
and I get the reply "Enter AT Mode"
I then go to "No Line Editing" and change it to "Both NL & CR"
Then I change the baud to "9600"
I then attempt any AT Model command but all I get is a reply that is the same as what I type. I never get "Ok". can anyone help me please?
From what I can tell it is just running the sketch and The commands are not getting to the BLE. Yes I tried updating to the 1.94 FW.
I then type "+++"
2015-10-29 01:58:54
You are welcome! That's great!
Leff
catttdaddy2000 wrote:Worked. I see with the newer FW update you just stay in 115200.
2015-10-28 19:32:14 Worked. I see with the newer FW update you just stay in 115200.
catttdaddy2000
2015-10-27 19:04:09 Hello,
How are you!
And as I know, the baud rate setting should always be 115200 instead of 9600, why you got "enter AT Mode" message in 9600, it's an occasion for 9600x12=115200 I guess. Plz try 115200 and let me know if it can help!
Leff
Leff
How are you!
Leff
