Forum >Wifi Bee-RN-XV
Wifi Bee-RN-XV
userHead Piero78 2015-11-04 09:19:04 8322 Views7 Replies
Hi, I've a question about the Wifi Bee-RN-XV. Are there problems to use this module with Arduino Leonardo or Arduino Mega? I've to use them with a Romeo based on Arduino Leonardo and with an Arduino Mega 2560.
Thanks.
2016-02-27 01:27:20 Hi Piero78,
How is it going!
Have your problem got solved now?
I tried on Uno but failed surprisingly, you said it will failed on Romeo and Mega, I thought you might overlook the serial number, you have to change the serial.**() to serial1.**() in the code to use it on Romeo or Mega COM1. But I am not sure why I failed on UNO, did yours worked?
I will go on this issue~
userHeadPic Leff
2016-01-14 18:57:54 Hi Piero 78, sorry to leave your question hanging.
Our engineering team are currently investigating this issue and will post the answer in this thread when we have it
userHeadPic Maht
2016-01-09 08:58:41 I repeat my question...
What are the steps for the sostitution of the product?
Thanks.
userHeadPic Piero78
2016-01-08 04:09:23 Hi bluehawk, you should follow this discussion. ;) userHeadPic Piero78
2016-01-07 22:03:04 Hi I got the same problem - the Bee is just not working - and I have tried everything . I got a Romeo V2 with it on. Sending to Serial1 and I see on the LED that data is transmitted but I don't get any response.. what can be wrong ?! userHeadPic bluehawk
2016-01-07 09:32:23 I've received the Wifi Bee-RN-XV but it doesn't works.
Thanks.
userHeadPic Piero78
2015-11-04 19:21:11 Hi,
No pro at all!
But notice that Leonardo has two serial ports, and Mega has 4. Read more on arduino.cc > SERIAL
userHeadPic Leff
