Forum >DFR144 Relay Shield
DFR144 Relay Shield
userHead jbm417 2015-11-06 09:16:09 9827 Views3 Replies
I have looked at the board layout & schematic, but cannot figure out if it is possible to use Arduino D4 to control Relay 1. Will someone help me with a simple answer?
TIA, Joe
2015-11-11 17:54:28
jbm417 wrote:Leff, thank you for the info. This is just what I needed.
Very happy that could help you!
userHeadPic Leff
2015-11-11 07:30:02 Leff, thank you for the info. This is just what I needed. userHeadPic jbm417
2015-11-09 19:04:19 Hi Joe,
Welcome!
It's easy to make it just by removing the pin-map on the board and then connect the pin to the any Digital pin, e.g. D4.
For example:
I removed the map on D2/IO3, and connect it by a wire to D3;
If I upload the sketch:
Code: Select all
  // initialize digital pin 13 as an output.
  pinMode(3, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(3, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(3, LOW);    // turn the LED off by making the voltage LOW
userHeadPic Leff
