ANALOG ELECTRICAL CONDUCTIVITY SENSOR CALIBRATION
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
Hi there,
I received the Analog Electrical Conductivity Sensor and it is not calibrated properly, can anyone help me find some code that will help calibrate it as the manual supplied was not clear on how to fix up calibration with the buffer solutions.
Thank you
Thank you
2018-12-24 10:32:24 Did you follow the wiki to calibrate the sensor? How it works with the sample code? https://www.dfrobot.com/wiki/index.php/ ... alibration
robert.chen
![userHeadPic](https://dfimg.dfrobot.com/dfPortrait2.png)
