Forum >Solar Power Manager Micro output current
im trying to connect a ESP-07 to the 3.3V output of the 'Solar Power Manager Micro'.
Because of its 90mA output it didnt work - just 1 sec. (ESP-07 has peak current of ~160mA)
The normal current is less than 90mA.
Is there a trick or something what i can do?
2019-01-03 18:16:26 The peak current and the start current of WiFi on ESP-07 is much larger than 90mA, so if you want to use this solar power manager to power ESP-07 directly is hard to realize, you can consider to use a battery to power it like the attachment shows.
robert.chen
