Forum >SENO0169 Showing nan or inf
I could it to work with the pH meter sample code v1.0 though I saw there was a newer version with the EC included (which I'll order once I know this is working. It says all I need to do is put it into ph 4 or 7 calibration liquid, which I have and all I'm getting is inf and if I do try CALPH is fails. I run the eeprom_clear code with no luck.
I also saw on another thread here for EC part of it to run the code below, doing so seems to make the reading go into the EC part of the Serialmonitor. I've added the V2.0 code at the bottom also.
Any help would be greatly appreciated!
Drew.
I saw on another thread it was suggested
Drew.
#include <EEPROM.h> #define KVALUEADDR 0x0A void setup(){ for(byte i = 0;i< 8; i++ ){ EEPROM.write(KVALUEADDR+i, 0xFF); } } void loop(){ }
/* * file DFRobot_PH_EC.ino * @ https://github.com/DFRobot/DFRobot_PH * * This is the sample code for The Mixed use of two sensors: * 1、Gravity: Analog pH Sensor / Meter Kit V2, SKU:SEN0161-V2 * 2、Analog Electrical Conductivity Sensor / Meter Kit V2 (K=1.0), SKU: DFR0300. * In order to guarantee precision, a temperature sensor such as DS18B20 is needed, to execute automatic temperature compensation. * You can send commands in the serial monitor to execute the calibration. * Serial Commands: * * PH Calibration: * enterph -> enter the PH calibration mode * calph -> calibrate with the standard buffer solution, two buffer solutions(4.0 and 7.0) will be automaticlly recognized * exitph -> save the calibrated parameters and exit from PH calibration mode * * EC Calibration: * enterec -> enter the EC calibration mode * calec -> calibrate with the standard buffer solution, two buffer solutions(1413us/cm and 12.88ms/cm) will be automaticlly recognized * exitec -> save the calibrated parameters and exit from EC calibration mode * * Copyright [DFRobot](http://www.dfrobot.com), 2018 * Copyright GNU Lesser General Public License * * version V1.0 * date 2018-04 */ #include "DFRobot_PH.h" #include "DFRobot_EC.h" #include <EEPROM.h> #define PH_PIN A1 #define EC_PIN A2 float voltagePH,voltageEC,phValue,ecValue,temperature = 25; DFRobot_PH ph; DFRobot_EC ec; void setup() { Serial.begin(115200); ph.begin(); ec.begin(); } void loop() { char cmd[10]; static unsigned long timepoint = millis(); if(millis()-timepoint>1000U){ //time interval: 1s timepoint = millis(); //temperature = readTemperature(); // read your temperature sensor to execute temperature compensation voltagePH = analogRead(PH_PIN)/1024.0*5000; // read the ph voltage phValue = ph.readPH(voltagePH,temperature); // convert voltage to pH with temperature compensation Serial.print("pH:"); Serial.print(phValue,2); voltageEC = analogRead(EC_PIN)/1024.0*5000; ecValue = ec.readEC(voltageEC,temperature); // convert voltage to EC with temperature compensation Serial.print(", EC:"); Serial.print(ecValue,2); Serial.println("ms/cm"); } if(readSerial(cmd)){ strupr(cmd); if(strstr(cmd,"PH")){ ph.calibration(voltagePH,temperature,cmd); //PH calibration process by Serail CMD } if(strstr(cmd,"EC")){ ec.calibration(voltageEC,temperature,cmd); //EC calibration process by Serail CMD } } } int i = 0; bool readSerial(char result[]){ while(Serial.available() > 0){ char inChar = Serial.read(); if(inChar == '\n'){ result[i] = '\0'; Serial.flush(); i=0; return true; } if(inChar != '\r'){ result[i] = inChar; i++; } delay(1); } return false; } float readTemperature() { //add your code here to get the temperature from your temperature sensor }
2025-01-07 13:55:30
amirulhafizan1995
Hi, I have the same problem calibrating my pH sensor with buffer solutions and use the exact same wiring and calibration code from DFRobot. I’m using Arduino Uno Board with sensor V2 module
[https://github.com/DFRobot/DFRobotMedia ... SEN0161-V2]
However, the serial monitor prints pH: nan or sometimes pH: inf
Can anyone help me resolve this issue? Cheers
2020-11-10 19:04:05 @slergos
It is strange. On my UNO board, I copy your code and upload it. It works fine. The readings are correct. Do you have a UNO board to test the same code? Thanks.
Youyou
2020-10-25 02:03:37 Same problem here !
i have recently bought an Analog pH Sensor/Meter Kit V2 SKU:SEN0161-V2
for a hydroponic controller project.
The controller I use for this project is Arduino Nano Every.
ti seems that the library you provide for this sensor is not functional for this controller.
when i'm done with hardware setup (sensors directly connected to controller via hook up wires) and upload the sketch i got the right readings on serial monitor for temperature and Ph voltage , on Ph conversion i get nan or inf outputs.
i have tried the same code on a second brand new arduino nano every , with clean EEPROM but i always get the same result.
Is there any functional library for this controller or any modifications that i can do on the library you provide to solve the problem ?
Ph sketch is attached.
Thank you .
sketch :
slergos
Thank you .
sketch :
//PH Sensor (SKU:SEN0161-V2) #include "DFRobot_PH.h" #include <EEPROM.h> #define PH_PIN 14 float voltage,phValue,temperature = 25; DFRobot_PH ph; //Temperature sensor (LM35) const int lm35_pin = 20; //* LM35 pin int LM_Temperature_sensor_read; void setup() { Serial.begin(115200); //Ph Sensor. ph.begin(); // LM35 Sensor. pinMode(lm35_pin, INPUT); } void loop() { static unsigned long timepoint = millis(); if(millis()-timepoint>1000U) //time interval: 1s { timepoint = millis(); voltage = analogRead(PH_PIN)/1024.0*5000; // read the voltage LM_Temperature_sensor_read = analogRead(lm35_pin); temperature = (LM_Temperature_sensor_read*0.488); // read your temperature sensor to execute temperature compensation phValue = ph.readPH(voltage,temperature); // convert voltage to pH with temperature compensation Serial.print("temperature:"); Serial.print(temperature,1); Serial.print(" C "); Serial.print("voltage: "); Serial.print(voltage,2); Serial.print(" pH:"); Serial.println(phValue,3); } ph.calibration(voltage,temperature); // calibration process by Serail CMD }
2019-09-13 02:56:56 It seems that some special values in the EEPROM, which cuase the problem. Would you like to clear all EEPROMs, then upload the sample code?
Youyou
2019-01-07 22:29:27 For the pH sensor, the V1.0 code can not work with V2.0 sensor, you can not use together.
robert.chen
