Forum >Blood Pressure sensor?
userHead Account cancelled 2019-01-14 18:10:46 2649 Views2 Replies
Hello there!!
I was wondering how could I get more data out of the Blood Pressure sensor?
Every time I use it works perfectly but it only gives me 5 measures, i tried to change the library at the BloodPressure but started to show me some crazy dates. What should I do to get 10 or more measures?
Thank you!!
Lee!
2019-01-17 03:09:47 High blood pressure is a common risk factor for heart attacks, strokes and aneurysms, so diagnosing and monitoring it are critically important. However, getting reliable blood pressure readings is not always easy. userHeadPic gayanbelousova1990
2019-01-14 19:23:50 Which blood pressure sensor do you mean? Do you mean the heart rate sensor? userHeadPic robert.chen
