Forum >RLY-8
Easy IoT General
RLY-8
userHead ales.ribic 2019-01-19 04:47:08 9946 Views19 Replies
I have a few RLY-8 boxes. It seems that they have some bugs... Where can i get source files for firmware?
2019-02-21 07:22:10 i have tryed today. On 485 converter LED is blinking when i click OpenCom in (Com set) app. After 2 second i get pop-up window saying: "search poe fail, enter manual mode"
Nothing is changing...
userHeadPic ales.ribic
2019-02-15 22:04:26 Do you have any USB to RS485 converter like this? https://www.dfrobot.com/product-1029.html userHeadPic robert.chen
2019-02-14 23:24:06 I have RS485 module. How to connet his over USB? userHeadPic ales.ribic
2019-02-14 19:16:56 Hi
Here is an easy way to test the module by com port.
Please connect the module to your PC by USB cable, then open the .exe software, choose COM control, open Com, then you can control the relay by click on/off, the LED on the module should be turn on/off.
2019-02-14 01:02:39 Hi
Thanks for your feedback. I have connected module directly to PC. Regarding reset, my led is blue colour. When i press "default" button, blue LED blinks fast a few times, then blinks slow for 10 seconds and then it starts to lit. It does not change colour.
When i did this procedure, module is still not reseted.
2019-02-11 22:33:59 Hi,
To reset the device, you can keep pressing the reset key until the light change the color, and how do you connect the module, did you connect directly to your PC?
2019-02-05 07:03:21 So any help, please? At least how to reset properly? userHeadPic ales.ribic
2019-01-22 06:23:45 I cant get device to show up in Enternet_Com_Control.exe, so i play around, and once i did get it to show up. Then i set static IP, but left DHCP=ON.
since then, device sometimes boot normally, but mostly not. When it does not boot also network LED's does not blink. I have to reconnect power a few times, and then randomly starts to work.
I have try-ed to reset to factory defaults, but no difference. Maybe im reseting it in a wrong way.
2019-01-21 18:54:43 What kind of bugs did you meet? userHeadPic robert.chen
2019-01-19 04:47:08 I have a few RLY-8 boxes. It seems that they have some bugs... Where can i get source files for firmware? userHeadPic ales.ribic
