Forum >maqueen project not compiled
RoboticsGeneral
userHead mi_semion 2019-01-26 11:18:09 10263 Views7 Replies
in makecode, I imported maqueen project from https://github.com/jhlucky/maqueen
it doesn't run: the message is
please add 'shims.d.ts' to 'files' in pxt.json.
Attempts to correct the project manually were not successful. System: Windows 10 home
Please help
2019-05-16 20:26:19
GraceGibson164 wrote:
Wed May 15, 2019 4:55 am
Thanks for sharing such a great information.. It really helpful to me..I always search to read the quality content and finally i found this in you post.
Any update?
userHeadPic GraceGibson164
2019-05-15 20:55:39 Thanks for sharing such a great information.. It really helpful to me..I always search to read the quality content and finally i found this in you post. userHeadPic GraceGibson164
2019-02-15 00:09:44 Hi,
I am having the same problem with the latest version of makecode. Only the leds works. Is there and updated version that I can import for the latest version of makecode. Thanks
userHeadPic ickhatib
2019-02-03 09:21:14 I fixed the problem with circuit on my side, now projects are working.
Still, the very first operation in documentation (importing maqueen project )looks unnecessary and confusing.
userHeadPic mi_semion
2019-02-03 02:52:15 tried a few projects. Only Leds are working. No moving, no distance measuring, no Ambient Light (I didn't try remote)
I'll try to program on pin level
2019-02-02 11:12:44 First, behaviour with project maqueen is known for a long time, as one can see on github.
When I tried the next link https://makecode.microbit.org/_2Cc9gM5P5aDs the program could be downloaded and moved into micro:bit/ It was running (I saw it when I added additional output to the program) but no move of the car
2019-01-28 18:16:38 Can you follow the wiki and upload the code to Microbit to see if it works? https://www.dfrobot.com/wiki/index.php/ ... U:_ROB0148 userHeadPic robert.chen
