Forum >Gravity: Analog pH Sensor / Meter Pro Kit For Arduino / measuring seawater
Ladies and Gentlemen,
I would like to use the Analog pH Sensor to measure sea water in my aquarium. The pH value here is always above pH 7. Can I also use buffer standards with pH 7 and pH 10 for 2-point calibration?
The product description states that the pH probe should be disconnected from the signal conversion board without a power supply after the measurement has been completed. How do I connect a power supply if I want to measure the pH value permanently?
Can I change the code for the continuous measurement?
Best regards
Best regards
