Forum >IR Remotes for Maqueen
RoboticsGeneral
userHead Account cancelled 2019-02-28 16:21:02 2395 Views1 Replies
Do you need a specific IR remote to make the IR remote sensor activate. I have tried several IR remotes and none are working. Also can someone post some microbit code to make sure I am using the code correctly ?
Thank you
John
2019-02-28 22:08:21 Do you mean to use IR kit to send command to Maqueen? Have you tried to read the IR sensor for Microbit, then use Microbit to control Maqueen? userHeadPic robert.chen
