Forum >Is it possible to feed an DFRduino UNO R3 with 14,2 V on Vin (automotive) ?
All is in the tittle ...
I do that whith UNO and MEGA (original)s but I have problems with NANO.
The specs are :
Input Voltage (recommended): 7 ~ 12V
Input Voltage (limits): 6 ~ 20V
So 14,2 V seem to be OK, but ...
Thanks for your answers ...
Michel
The specs are :
Michel
2019-03-01 18:42:54 Yes, you can use 14.2V input, the only problem is the Arduino may heat up (but still safe).
robert.chen
