Forum >SEN0140 mounting details
userHead Account cancelled 2019-03-21 17:32:56 1377 Views1 Replies
I want to use a number of these SEN0140 modules in a pre-production run so am designing this SEN0140 module onto a PCB carrier board for interfacing. Can you please advise where I can find connector position information relative to board dimension etc. I could measure off a physical board but that is a little inaccurate.
2019-03-27 21:47:34 Is this picture clear enough to show the dimension of the holes and the pin connector's space is 2.54mm. userHeadPic robert.chen
