Forum >Guide to configuring as a HID keyboard
Bluno General Arduino
userHead graham 2019-03-28 08:32:43 3154 Views0 Replies
So, from my previous topic; viewtopic.php?f=18&t=16539 it seems the bluno firmware is just not compatible with OSX's CoreBluetooth implementation. Why, I don't know (if DFRobot can opensource the firmware, that would be great and I could fix it)
Other devices work fine (eg. BBC micro:bit) so the bug is with the bluno firmware.
My fallback plan was to create a HID device, as that DOES work.
After a few days of headaches, this process is how to make it work. This solves various problems like when arduino will no longer update sketches when in HID mode.
// How to setup Bluno
// Reset so we can flash
// - Connect with serial
// +++<no line endings> to go into AT mode
// AT_SETTINGS=DEFAULT<NL&CR> to reset
// Re-power to reboot BLE (AT+RESTART doesnt always seem to work)
// Upload sketch (should upload and immediate start printing out AT+KEY=0)
// Configure for HID
// AT+NAME=SpraycanX
// AT+UART=115200 // make sure this matches the baud rate for Serial.begin()
// AT+FSM=FSM_HID_USB_COM_BLE_AT
// AT+USBDEBUG=ON // optional
// Re-power, connect with bluetooth (should pair first time) and button should work as Key
I'll tart up this post at some point, but it's a reference before I lose it.
With this method I have finally made 6 bluno's talk to my OSX corebluetooth code!
