Forum >DFR0548 Max Input voltage
RoboticsGeneral
userHead gentijo 2019-03-29 21:50:59 3370 Views2 Replies
I just purchased a few of the DFR0548 and then actually read the specs. I see that you are stating a max VIN of 5.5 volts which is a little on the low side when trying to retro fit a 7.2 VDC RC Car or Truck with a MicroBit + expansion board.
In looking at the schematics I see that the SPX3819 has a fairly wide input range, all the way to 16 VDC and the drv8833 motor controller can handle a VM of up to 10.8 volts. It seems that the DFR0548 should be able to handle a similar input range to the https://www.dfrobot.com/product-1492.html board.
I don't see VIN tied to anything else that may have a lower input voltage tolerance, can you let me know if you thing 10V on the input voltage would stress anything ?
http://www.ti.com/lit/ds/symlink/drv8833c.pdf
http://www.mouser.com/ds/2/146/SPX3819_ ... -17072.pdf
2019-04-02 01:16:56 The Vin need to be 3.5~5.5V userHeadPic robert.chen
2019-03-30 09:52:28 I see now that anything plugged into J2 will have Vin as a power source, so those outputs may need to be treated with caution. userHeadPic gentijo
