Forum >Wireless GamePad V2.0 for Arduino - Connecting to programmer: .avrdude: butterfly_recv(): programmer
userHead mgruber 2019-04-02 04:40:21 3882 Views2 Replies
Trying to upload the test code to the gamepad, getting error...
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
I've read that the trick with the Leonardo board is to reset it at some specific point during the upload to get it to accept it.
On the product page https://www.dfrobot.com/product-858.html
It states, "Includes a Turbo button used to reset the controller", but I cannot see a "turbo" button, I can see...
- Select
- Start
- Analog
- 1, 2, 3, 4
- front "1" and "2"
but no turbo, please advise.
Also at what point do I hit the reset button, just to be clear.
Here's the output from the Arduino IDE
Sketch uses 6888 bytes (24%) of program storage space. Maximum is 28672 bytes.
Global variables use 411 bytes (16%) of dynamic memory, leaving 2149 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM11
PORTS {COM11, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {} => {}
PORTS {} / {COM11, } => {COM11, }
Found upload port: COM11
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM11 -b57600 -D -Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino_build_379339/DFGamepad_1.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM11
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
regards
Michael
2019-04-02 18:59:25 Managed to reload the bootloader on the gamepad, now visible on the device manager.
However, I still need to know where the physical reset (Turbo) button is so I can apply the upload workaround documented here -> https://www.arduino.cc/en/Guide/Arduino ... Micro#toc6
userHeadPic mgruber
2019-04-02 05:16:56 Hi,
Just tried to use the ICSP port to download a Leonardo bootloader using the Arduino IDE, now the gamepad does not appear at all in the device manager.
Any assistance how to get back to square 1 - i.e. factory default would be appreciated.
regards
Michael
userHeadPic mgruber
