Forum >How to control Arduino wirelessl/ bluetooth by phone
userHead Leff 2015-12-16 02:48:14 8705 Views0 Replies
STEP1: Preparation:
______________________________________________________________________________________________
Hardware:
1. USB to TTL Converter x1
2. Expansion shield x1
3. Phone with BT2.0 above x1
4. BT3.0 module x1
5. DFRobot Uno x1 ( Compatible with Arduino Uno)
Software:
1. Arduino IDE
2. BT serial App for your phone, here I used one for Android (Bluetooth Terminal.apk)
2 APP for Android.zip (1.95 MiB) Downloaded 830 times
Note: The switch of the AT mode should be on the correct position, or it doesn't work. :)
STEP2 Setting BT Module
_______________________________________________________________________________________________
1. Default setting is ok. Visit wiki for how.
STEP3 Download Sketch to Uno
plz turn expansion switch "PROG/RUN" to PROG or will cause upload fail. :!: And remember turn it to RUN after finishing uploading. ;)
The sketch here is to receive the data from serial port ( i.e. BT module), and then, it will
1) Turn On the LED on D13 if you send "1";
2) Turn OFF the LED on D13 if you send "0";
3) Store the command and print out through serial port.
Code: Select allString val = "";
boolean mark = LOW;
  Serial.begin(38400);  //initial the Serial
  pinMode(13, OUTPUT);
  while (Serial.available()) {
    val += char(Serial.read());
    delay(2);   // Can't be deleted for it needs time to read serial
    mark = HIGH;
  if (val.length() == 1) {    //Send command without CR/ LF/ NL
    if (val == "1") {
      digitalWrite(13, HIGH); //turn on the LED on D13
      Serial.println("LED is ON!");
    else if (val == "0") {
      digitalWrite(13, LOW);  //Trun off
      Serial.println("LED is OFF!");
  if (mark == HIGH) {
    Serial.print("Length: ");      Serial.println(val.length());
    Serial.print("Val: ");        Serial.println(val); delay(50);
    Serial.println("Done");       Serial.println();
    Serial.flush();
    val = "";
    mark = LOW;
STEP4 Connect BT module with your phone
1). Connect BT module from SETTING PANEL
2). Open app "Bluetooth Terminal", and set its command sending format as NONE, then send command as you want, here, I sent
1. 1 -> Turn on the LED
2. 0 -> Turn off the LED
3. Test finished!
One more thing: You can also open Arduino Serial Monitor to receive the feedback info
