Forum >TF Mini LiDAR(ToF) Laser Range Sensor
userHead Account cancelled 2019-04-05 09:09:38 6048 Views3 Replies
I purchased 2 of these to use with an Arduino Project I am doing. When working independent they produce accurate results, however when put together one sensor reads about 15cm different than the other pointing to the same distance.
Any insight would be helpful.
2019-11-21 04:43:38 thanks! That basic info
https://www.dfrobot.com/wiki/index.php/ ... U:_SEN0259
was really helpful
userHeadPic marinabehance
2019-11-17 15:07:27 I'm interested in using a TF Mini LIDAR in a project but need to know a couple things that aren't in the specs (or at least I haven't seen any data on these questions).
1) How will the device perform at up to 10 meters when there is relative motion between the TF Mini LIDAR and the target? That relative motion can be up to 100-120 mph.
2) How well will the device perform when the target is the ground, or earthworks of some sort (embankment, berm , etc)?
userHeadPic d.f.clark
2019-04-10 22:30:15 What is the distance you measure, there should be some accuracy error when measuring the distance. userHeadPic robert.chen
