Forum >DFR0563 Gravity Gas Gauge Problems
Having problems with the DFR 0563 Gravity Gas Gauge. I can see input voltage (3.5-4.2 from fresh LiPo battery) at the terminal block. There is 0 volts on the i2c connector. Do I have a defective unit?
2019-04-12 07:56:06 I do not believe wiring is the issue. It is wired as follows:
btuzin
- Green - 22
Blue - 21
Red - VCC
Vlack - Ground
