Forum >Small but quiet motor
RoboticsGeneral
userHead phil 2019-04-19 20:51:51 3574 Views3 Replies
I am looking for a motor to replace one I already have.
I have a small gear motor from Polou but as soon as I mount it, the vibrations make too much noise.
This one from DFRobot has the perfect spec but I'm curious if anybody has tried it and if it is noisy.
https://www.dfrobot.com/product-1523.ht ... tor&page=3
Cheers
Phil
2019-04-20 07:19:42 The one I currently use is tis one.
https://www.pololu.com/product/1596/resources
I am would love to know if the DFRobot motor with similar spec would have the same issue.
userHeadPic phil
2019-04-20 07:17:50 The noise is fine when I'm holding it but as soon as I mount it in my enclosure or even put the motor on my bench, the noise increases and that noise is too loud.... userHeadPic phil
2019-04-20 02:55:09 The noise comes from the gear box, I am not sure how nosiy you can endure. userHeadPic robert.chen
