Forum >Arduino MKR1000 & DFRobot Liquid Level Sensor Compatibility
Easy IoT General
userHead james.b.hall 2019-05-03 02:17:08 5826 Views2 Replies
I have purchased the Arduino MKR1000 & DFRobot Liquid Level Sensor IR02 for a work project and was wondering whether the 2 are compatible without further components.
To advise, I have downloaded the software for the Arduino MKR1000 and run a few of the example programs like Blink successfully.
The DFRobot Liquid Level Sensor IR02 comes with a 3pin adaptor that I have tried on the Arduino MKR1000 without success, I was curious as to whether any other components are required to get these to work together or whether I'm doing something wrong.
Code being used:
int Liquid_level=0;
Serial.begin(9600);
pinMode(5,INPUT);
Liquid_level=digitalRead(5);
Serial.print("Liquid_level= ");Serial.println(Liquid_level,DEC);
delay(500);
Thanks in advance for any replies.
2019-05-14 22:44:52 Hi, thanks for the reply, the SKU number is: FS-IR02 V1.0 userHeadPic james.b.hall
