Forum >Gravity Electrical Conductivity Sensor
userHead Account cancelled 2019-05-11 07:55:04 1581 Views1 Replies
How do I know if the EC sensor I am working with is damaged? The voltage values that I read in the 1413 uS/cm buffer solution is higher than the values I read in the web. In a sample code I found, it should be around 216 mV, whereas the values that I read is around 900. Thank you for answering.
2019-05-18 01:29:17 Have you tried calibrate the sensor? userHeadPic yolande_shaw
