Forum >SIM 7000 Arduino Board
i have Problem to use the board with Arduino.
If i use the Script the Modem did not answer.
I Think that is that the software serial port only goes up to 38000 baud and not up to 115200.
With the onboard USB nothing happend the computer found nothing althoug i use external 5V vfom Arduino to power up the module.
Who can help me to set the baud rate to 19200?
2019-09-18 03:40:13
verenicolson
Can you please confirm that the external power should be supplied to the VIN pin (12v+ve) and GND pin (12v -ve)
2019-09-18 03:40:13
verenicolson
2019-05-28 07:46:55 Is it posible to set with the internal usb adapter to use IPREX=19200 to set baud rate?
The computer could not find the board with the internal usb.
snoopy-1
snoopy-1
2019-05-28 02:51:01 Hello,
the Network LED is not flashing. Only the lamp on is on.
This i have don often Times.
snoopy-1
snoopy-1
2019-05-22 04:42:19 Hello,
snoopy-1
