Forum >What is the duty cycle and expected lifetime of the relays on the RLY-8?
We are using 6 of the RLY-8 in a prototype industrial control application. Occasionally, we must cycle the relays on/off at approximately 1 second intervals for up to an hour (~1800 on/off cycles in an hour). This can occur up to 6 times per 24 hour period.
Can you supply the duty cycle and expected contact closure/open lifetime based on switching 110 VAC at about 0.25 amp? Alternatively, please respond with the part number of the relay and we can do the necessary research.
Regards, Ira Grollman
2021-07-15 22:32:38 I absolutely concur with you. Almost certainly that computerized reasoning is supplanting people in numerous fields but students need to visit https://www.skymetweather.com/content/l ... r-service/ to manage their tasks, at the same time it tends to be pretty much as successful as the human brain since the human psyche is more perplexing and no machine can be so precise.
tafep67142
2019-05-25 05:24:42 Thanks! We will verify this data as the installed base uses the device and provide feedback based on actual performance.
iragrollman
