Forum >SIM7000E Help
Easy IoT General
SIM7000E Help
userHead perry.costa01 2019-05-31 18:32:39 9561 Views8 Replies
I have followed the steps of the wiki and have had to alter code due to certain parts not being found in the "DFRobot_SIM7000.h" the code is:
#include <Wire.h>
#include <DFRobot_SIM7000.h>
#define PIN_TX 0
#define PIN_RX 1
SoftwareSerial mySerial(PIN_RX,PIN_TX);
DFRobot_SIM7000 sim7000;
static char buff[350];
void setup(){
int signalStrength,dataNum;
Serial.begin(115200);
sim7000.begin(mySerial);
sim7000.turnOFF();
delay(5000);
Serial.println("Turn ON SIM7000......");
if(sim7000.turnON()){ //Turn ON SIM7000
Serial.println("Turn ON !");
Serial.println("Set baud rate......");
if(sim7000.setBaudRate(19200)){ //Set baud rate from 115200 to 19200
Serial.println("Set baud rate:19200");
}else{
Serial.println("Faile to set baud rate");
while(1);
Serial.println("Check SIM card......");
if(sim7000.checkSIMStatus()){ //Check SIM card
Serial.println("SIM card READY");
}else{
Serial.println("SIM card ERROR");
while(1);
delay(500);
Serial.println("Set net mod......");
if(sim7000.setNetMode(NB)){ //Set net mod NB-IOT
Serial.println("Set NB-IOT mode");
}else{
Serial.println("Fail to set mode");
Serial.println("Get signal quality......");
delay(500);
signalStrength=sim7000.checkSignalQuality(); //Check signal quality from (0-30)
Serial.print("signalStrength =");
Serial.println(signalStrength);
delay(500);
Serial.println("Attaching service......");
if(sim7000.attacthService()){ //Open the connection
Serial.println("Attach service");
}else{
Serial.println("Fail to Attach service");
while(1);
delay(200);
Serial.println("Connecting......");
if(sim7000.openNetwork(TCP,"www.hologram.io",80)){ //Start Up TCP or UDP Connection
Serial.println("Connect OK");
}else{
Serial.println("Fail to connect");
while(1);
sim7000.send("HEAD/HTTP/1.1\r\nHost:www.taobao.com\r\nConnection:keep-alive\r\n\r\n"); //Send Data Through TCP or UDP Connection
dataNum=sim7000.recv(buff,350,0); //Receive data
Serial.print("dataNum=");
Serial.println(dataNum);
Serial.println(buff);
delay(500);
if(sim7000.closeNetwork()){ //End the connection
Serial.println("Close connection");
}else{
Serial.println("Fail to close connection");
delay(2000);
sim7000.turnOFF(); //Turn OFF SIM7000
delay(1000);
The errors coming up are:
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `setup':
D:\data\My Documents\Arduino\sketch_may31a/sketch_may31a.ino:13: undefined reference to `DFRobot_SIMcore::begin(Stream&)'
D:\data\My Documents\Arduino\sketch_may31a/sketch_may31a.ino:14: undefined reference to `DFRobot_SIMcore::turnOFF()'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `turnON':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:232: undefined reference to `DFRobot_SIMcore::setRate(long)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:233: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:234: undefined reference to `DFRobot_SIMcore::turnOFF()'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:236: undefined reference to `DFRobot_SIMcore::setRate(long)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:237: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:238: undefined reference to `DFRobot_SIMcore::turnOFF()'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:248: undefined reference to `DFRobot_SIMcore::setRate(long)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:249: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:251: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:260: undefined reference to `DFRobot_SIMcore::setRate(long)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:261: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:263: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `setBaudRate':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:40: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:60: undefined reference to `DFRobot_SIMcore::setRate(long)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `checkSIMStatus':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:71: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:83: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `setNetMode':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:100: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:102: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `checkSignalQuality':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:176: undefined reference to `DFRobot_SIMcore::cleanBuffer(char*, int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:177: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:178: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `attacthService':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:129: undefined reference to `DFRobot_SIMcore::cleanBuffer(char*, int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:130: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:132: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:141: undefined reference to `DFRobot_SIMcore::cleanBuffer(char*, int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:143: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:155: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:157: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:165: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `openNetwork':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:198: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:199: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:200: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:202: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:203: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:217: undefined reference to `DFRobot_SIMcore::cleanBuffer(char*, int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:218: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:216: undefined reference to `DFRobot_SIMcore::checkReadable()'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `send':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:292: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:293: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:294: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `recv':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:550: undefined reference to `DFRobot_SIMcore::cleanBuffer(char*, int)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:551: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
C:\Users\91968\AppData\Local\Temp\ccWXik24.ltrans0.ltrans.o: In function `closeNetwork':
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:601: undefined reference to `DFRobot_SIMcore::check_send_cmd(char const*, char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:295: undefined reference to `DFRobot_SIMcore::send_cmd(char const*)'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:297: undefined reference to `DFRobot_SIMcore::checkReadable()'
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.cpp:298: undefined reference to `DFRobot_SIMcore::readBuffer(char*, int, unsigned int, unsigned int)'
D:\data\My Documents\Arduino\sketch_may31a/sketch_may31a.ino:74: undefined reference to `DFRobot_SIMcore::turnOFF()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
If anyone would be able to give some help I would be very grateful :D
2020-03-28 23:12:19 Good day,
I am having similar issues. Suspect it relates to the setNet vs setNetMode methods that are different in your example and library.
Code on your wiki at https://wiki.dfrobot.com/SIM7000_Arduin ... 05_DFR0572 refers to setNet method as per below:
Code: Select all
delay(500);
if(sim7000.setNet(NB)){ //Set net mod NB-IOT
}else{
When looking at code on github at https://github.com/DFRobot/DFRobot_SIM7 ... IM7000.cpp, it refers to setNetMode
Code: Select all
bool DFRobot_SIM7000::setNetMode(Net net)
if(net == NB){
mode_t=0;
Please can you advise?
AA
userHeadPic andries.arenek
2019-06-03 23:00:05 With the new library the errors are now:
In file included from d:\data\My Documents\Arduino\libraries\DFRobot_SIM-master/DFRobot_SIM.h:7:0,
from D:\data\My Documents\Arduino\sketch_may31a\sketch_may31a.ino:2:
d:\data\My Documents\Arduino\libraries\DFRobot_SIM-master/DFRobot_SIMclient.h:6:6: error: multiple definition of 'enum Protocol'
enum Protocol {
In file included from D:\data\My Documents\Arduino\sketch_may31a\sketch_may31a.ino:1:0:
d:\data\My Documents\Arduino\libraries\DFRobot_SIM7000-master/DFRobot_SIM7000.h:9:6: note: previous definition here
enum Protocol {
exit status 1
userHeadPic perry.costa01
2019-06-02 23:07:37 Hi,
I haven't altered library. I altered the code to fit it to the library. Which was only 3 changes:
Line 36, from setNet --> to setNetMode
Line 56, from connect --> to openNetwork
Line 68, from close --> to closeNetwork
That's all :/ if you run the code they aren't found in the file: DFRobot_SIM7000.h
But the altered forms are.
