Forum >Maqueen V3
Maqueen V3
do you know if there is a program preferably as a hex file to check and test all functions of the Maqueen V3.0.
I can't run the engines with any code.
leds and the leds from the microbit board do it and I also see the code run through that is made in makecode.microbit.or but the engines remain still.
please help with running the engines of te Maqueen V3
