DFRobot_EC Library doesn't work
I just tried to install the DFRobot_EC library for Arduino on the web-based Arduino IDE (https://create.arduino.cc/editor) and it doesn't recognise the library. Can you check if you correctly packaged the library in order for Arduino to open it?
I'm using the following DFRobot_EC library for Arduino:
https://github.com/DFRobot/DFRobot_EC/a ... master.zip
2019-07-02 10:57:14 Could you use the offline IDE(https://www.arduino.cc/en/Main/Software)?
It works fine. Youyou
