Forum >Use TEL0117 LoRa board
RoboticsGeneral
userHead Account cancelled 2019-07-11 00:28:56 3045 Views1 Replies
Kind tech support, I wolu like to use your module (TEL0117) to implement a wireless communication channel. I have downloaded the document YL-800N, in which is described how must be connected the pins and how the network works. In one on the pictures there is "Mesh Network Module Configuration and Test Tool", where can I find this software to setup the modules? Thank you in advance. Regards.
