Forum >MIND+ v1.56 Event detection problem
Mind+General
userHead anonymous 2019-07-13 00:39:14 27504 Views6 Replies
In the new version, in ONLINE mode, the event HAT blocks do not detect button presses, shakes, etc.
They all worked correctly in the v1.53.
I have reported other button press issues earlier. But I think they all originate from the same problem, that events blocks are not activated.
Very urgent, as it makes the micro:bit unusable.
thx.
2022-05-14 01:06:49
Yes, I agree that self-learning and development should be given time every day
userHeadPic AdamzSendler
2019-12-22 01:43:55 Its sounds good. It means a new version , in ONLINE mode is going to launch soon. userHeadPic missangeltabassum
2019-08-02 17:41:27 Thanks for your suggestion, we will fix the problem in the next version1.5.7 soon.
Frances
userHeadPic anonymous
2019-08-01 22:26:24 OK. That has temporarily solved the problem!
However, since MIND+ is SCRATCH3 based and there is such problem in S3, you guys have injected a problem into the language switching portion of the code. Would it not be better for you to fix the problem than make the user go through language selection acrobatics to make your code initialize properly ?
2019-07-28 00:43:28 Hi, really sorry for the late reply.
First of all, thank you for your support about our Product. Here is the solution for your problem:
If now you are in English Interface, switch to Chinese, switch to English, close and reopen the software, then all the blocks should work fine; If you not in English Interface currently, switch to English, close and reopen Mind+.
Hope this helps! If you still have any questions, please let us know, we will try our best to make it right!
2019-07-25 23:08:02 Two weeks and no reply !!!! userHeadPic anonymous
