Forum >SIM800C GSM/GPRS Shield V2.0
Is this shield compatible with 3.3V Arduinos (namely, the DUE)? If not, do you have a similar shield that is compatible?
2019-08-17 14:00:07 Thanks for your response!
External power is definitely needed! I was more concerned about the voltage level on the serial connection. I ended up plugging it in to the DUE, and it it seems that it uses the correct output voltage based on the IOREF pin [5V on most Arduino's, but 3.3V on the DUE] --- good news!
msteinhoff43
