Forum >Bluno project
Bluno General Arduino
Bluno project
userHead Account cancelled 2015-12-30 12:46:15 3087 Views1 Replies
Hello we started project arduino tracked robot with bluno, we programmed everything, we coudl control it by pc. We tried later to set it up by bluetooth. We could pair bluno and smartphone, but when we got to app it wouldnt let us to connect to it.
here are the apps we tried
https://play.google.com/store/apps/deta ... .arduinorc
https://play.google.com/store/apps/deta ... tick&hl=en
Also here is hte photo http://postimg.org/image/4rthpx5fb/ of our system how we connected it (the only thing that we have changed was adding switch on the supply), however we think the problem is somewhere in the bluno not the connection or code, we would appreciate every help.
2015-12-30 19:06:00 Hi David, thanks for posting.
We have developed some of our own apps for bluetooth control on apple devices. If you have access to an apple device, they are available on the app store: https://itunes.apple.com/us/developer/s ... d643548685
It looks like GoBLE might be a good option for this project.
However, it looks like you want to use an Android device. Details for a compatible Android app can be found at the following links
https://www.dfrobot.com/wiki/index.php?t ... KU:DFR0267
https://play.google.com/store/apps/deta ... obotremote
You might also need to change settings via AT commands to get it to work properly. Details for this can be found on the product wiki page posted above.
Let me know what happens, good luck.
userHeadPic Maht
