Forum >Reverse voltage protection for GMR V1.1 Board
RoboticsGeneral
userHead vinaykuh 2016-01-22 11:22:35 6862 Views2 Replies
Is there any reverse voltage protection built into GMR V1.1 board?
I had an issue with the power management system and I think it reversed the polarity to board power inputs. I see that SX3478 blew off immediately. Do you think other power management ICs (LM2596s) would also be affected?
Please let me know. Thanks.
2025-01-17 11:12:35
Welcome!
I only found these three IC about power regulator, but didn't find the SX3478 you mentioned, could you indicate me that with a picture?
CX1117-33
LM2596S-ADJ
GS2678
And according to the schematic, it seems there is no reverse voltage protection.
userHeadPic Leff
2016-01-30 17:46:47 Hi Leff,
Thanks for your answer. I could see those three PMICs on the schematic. And I also agree with you that there is no reverse voltage protection.
GS2678 and SX3478 are pin-to-pin compatible ICs. In the GMR board I have, they have added SX3478 instead of GS2678. Please see the attached image.
userHeadPic vinaykuh
