Forum >CAD Models for HCR Robot
I am writing and Arduino and ROS nodes for HCR Robot. This package will have Arduino codes for GMR board (controlling motors, reading encoders and other sensor readings) and ROS node codes. I will be making the modules open source and would like to help others pickup easily on mobile robotics experiments.
Is there any way that I can get the CAD models of HCR robot? I am sure DFRobot people should have it from their design. I am currently manually measuring robot dimensions and writing URDF for the robot. It would be really helpful, if you could share the CAD files. I can refer them and make the URDF/ROS package more accurate.
2016-02-03 14:35:28 Hi Maht,
I have the one with Kinect stand and black wheels. (SKU: ROB0004). Let me know if you need any other details.
vinaykuh
2016-02-01 21:41:19 Hi there, thanks for the enquiry
Can you tell me the version of the HCR you are using? Do you have the SKU number? there are some different versions...
Maht
