Forum >Radial force 12V Low noise DC Motor 146RPM w/Encoder
Hi!
I am working on a robotic project building a autonomous omnidirectional robotic platform, using 4 12V Low noise DC Motor 146RPM w/Encoder and 4 meccanum wheels. Regarding this i am wondering how much stress/ weight each motor/gearbox can handle before the bearing breaks or become damaged? The weight of our platform would be 25 kilograms, the width of each wheel is 50 mm and the radius of each wheel is 50 mm. The wheels will be mounted directly on the motors axle.
Thank you
Thank you
