Forum >Vortex still not functioning properly.
General Robotics
userHead Vigliotti Louis 2016-02-15 14:51:56 4722 Views3 Replies
What's with the Vortex robot? More specifically, why doesn't this thing work with the latest version of WhenDo? Now the issue is the lack of connection through Bluetooth. If you use the Vortex app everything seems to work fine, however the app has a crippled version of WhenDo.
At the moment I have three pretty useless "robots".
2016-03-10 19:24:50 Hi,
Just pass by... and drop a line.
I never met this problem, but just a remind that (except Rex's one_Close other apps to make sure Vortex BLE service is free. Better restart it again.) WhenDo is not like VortexBot app which has a nearby-connection feature, you have to search it manually, and connect.
userHeadPic Leff
2016-02-16 13:41:32 Terminated and deleted. Still WhenDo doesn't work. Are other folks having similar issues? userHeadPic Vigliotti Louis
2016-02-15 17:04:15 Hi,
I am assuming you have both applications on your iPad. Please try to completely terminate the Vortex game app when you want to switch to WhenDo.
Please notice that you need to terminate either application completely ( double tap home button and swipe the application out of the screen ) to make it stop trying to make bluetooth connections. Any bluetooth-based devices can only connect to one application at a time, so you need to manually terminate other application.
We have registered this problem and are working on a solution to work around this issue.
Thank you very much.
Vigliotti Louis wrote:Hi,
userHeadPic Xia Rex
